Re: Message center does not like the cold!
Yup. I'm a heal. Somehow you got lost in my mix.
Sounds like you've got a handle on it. Don't envy you. Loose connections can be tough to track down meaning it could be a connection in a nice big wire harness connector or a tiny connection on a microprocessor circuit. Hope it's the former.
The Junction Block (JB) at the left lower side of the dash holds the relays on the inside of the van. The combo flasher, 3 door lock, rear defrost, and courtesy lamps relays are there. On the back side of the JB is the Body Control Module (BCM). The BCM controls the message center. The BCM is a microprocessor that controls and conditions much of the electronics in the van. It's the box with the chimes.
20 amp fuse #6 on the JB appears to power the message center. It also powers the climate control panel. Seeing problems there too?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
**DIYer and multiple automotive forums junkie for years. Air Force career in aviation electronics.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan / 94 Camry
