01 clk brake job tool requirements
lodownlv
01-10-2009, 03:10 AM
Anyone know the tools required to replace the pads and rotors on a 01 clk 320 I have limited tools and need to know what I need to do the job without running to the parts store a million times
Thanks!
eclass
01-12-2009, 05:54 PM
The calipers slides are metric 7mm allens if i remember correctly ( I could be wrong) and the bolt that holds the rotor on is a 4 or 5mm allen. The bolts for the caliper bracket are 16mm bolts?? Just get some metric sockets and allens, that will cover it.
lodownlv
01-25-2009, 12:28 PM
Thanks For The Reply Do You Know If You Need To Reinstall The Sensors Or Can You Just Disconnect Them With No Error?
eclass
01-27-2009, 05:32 PM
You can leave them off and not have any problems but why. I would recommend reusing the old ones or installing new. It would be a bad deal if you went through another set of pads and started to grind in the rotor before noticing the problem.
