Re: 99 Astro hard to start only in morning
Check fuel pressure and leak down rate. Most auto parts stores have fuel pressure testers for under $30, Harbor Freight has them for under $20. Quick, easy test checks the entire fuel delivey system. Key on, engine off, fuel pump running, pressure must be 60psi to 66psi. Must remain above 55psi for 3 to 5 minutes after the pump shuts off. Post your results.
