99 Intrepid ES - bump shift in Transmission
Google
Web AF
Augustaglen
01-05-2009, 10:37 PM
My intrepid has about 105000 miles on it and I was not sure if it had its ATF flush service ever before. I just had a ATF Flush service at a shop and right after that, the transmission started acting weird. The shift change from 2nd to 3rd is really bumpy and sometimes takes a little time which never happened before. I went back to the shop and they rechecked the fluid level--- it was fine. I have driven it probably 200~300 miles after the service.
After checking all the information that I could possibly collect on internet, I found out that using Dexron for my car's transmission is really bad. After all, I found out that the shop put Valvoline MaxLife--- which contains Dexron and Mercon mixed up--- into my car. I really hope that the cause is it, and I will be doing the ATF flush at the Dodge Dealer asap and ask them to put Mopar ATF+4.
Are there any other possible cause for the problem?? Or are there anything else to do to solve this problem?? I'm really worried and hope it's not too late!
Google
Web AF
