04 Corolla maint advice95astroman 01-05-2009, 08:35 AM I have an 04 Corolla approaching 100K miles and runs fine but I want to know if the 1.8L engine requires a timing belt change or any other preventative service that might prevent a major repair for a car with this mileage? The CV boots aren't cracked and I've replaced disc pads and changed oil (Mobile1) and there are no leaks. The auto trans seems fine but I haven't serviced it. I just got the recall notice on the window mechanism. This car is driven with care. Any advice welcome. Thanks again for a great site. GSS123 01-05-2009, 10:04 AM I would have the transmission flushed. Can't help you on the timing belt issue. I know they have gotten away from the belts with newer engines I just don't know what year it started. jdmccright 01-05-2009, 01:51 PM Check your owner's manual for what periodic maintenance is needed. Typically spark plug change, tranny/diff, & brake fluid changes, maybe coolant change/flush, and timing belt (if equipped). Spraying down the rubber boots, bushings, and CV boots with silicone lube spray will help keep them pliable. I also spray some onto an old clean rag and wipe down all the rubber door and trunk seals. Armor-All or Turtle Wax's Shine 2001(?) are similar. Hope this helps! roadrunner2 01-05-2009, 11:47 PM Your 1.8L I4 has a timing chain. I have the same engine in my '04 Matrix. I'm amazed the manual and supplement doesn't provide better service info. I can tell you the iridium spark plugs need replacing at 120k miles. To be safe change the trans fluid and clean filter every 40k miles or less if operating in a very dusty environment. Automotive Network, Inc., Copyright ©2012
