Cam position sensor? Cylinder not firing!invain 01-02-2009, 01:32 PM Been having a problem with a cylinder not firing in my 98' Nissan 240sx. First thing I checked was spark, which was all good. I know compression is fine in that cylinder, and the plug was dry when I pulled it so I know fuel is the problem. Checked/swapped injectors and found that wasn't the problem. I found very low voltage at the injector plug so we ripped into the harness and found a small short in the 12v wire to the injector. Fixed that and now the voltage is fine. However, the injector is still not receiving a ground signal from the ecu. We tested continuity in the ground wire all the way to the ecm harness connector and it was fine. I have a second ecu for the car so we swapped that in which changed nothing as well, which rules out an ecu problem. The only thing left I can think of is the Cam position sensor not working correctly. We tested contiunity in all the wiring for the sensor following the fsm instructions and found on problems. Now I need to know if there's any way to check if the cmps (cas) is actually sending the correct signals or not. Could a faulty cam position sensor cause only one cylinder to misfire/not fire? I really have no clue what else the problem could be. This problem has been real intermittent which made me think it was originally a wiring problem, but we've tested pretty much every connection possible and they're all fine. vgames33 01-02-2009, 04:29 PM You can look at the signal's waveform with an oscilloscope. There could be a bent fin or something causing a bad signal for the cylinder at fault. PROTEUS77 01-08-2009, 10:05 PM i have never seen a Nissan not fire on one cylinder with a faulty cam sensor,if the sensor is bad it will not fire at all. unfortunatly with out looking at the car i can't give you an idea where else to look but i know that when the cam sensor is bad they Nissan will not start. shorod 01-08-2009, 11:27 PM I wouldn't expect you to have spark on that cylider if you had a bad CMP sensor signal. If I were in your position, I'd check the signal to the injector either with an oscilloscope or with a noid light. You say it's not receiving a ground signal. How did you attempt to measure that? Did you duplicate your setup on another injector that is working fine to make sure your test aparatus was good? -Rod curtis73 01-09-2009, 08:41 AM The CPS on a Nissan just tells the ECU where TDC is (I thought). I would try a known good ECU. Its possible the relay for that injector is bad in the ECU. shorod 01-09-2009, 11:10 PM The CPS on a Nissan just tells the ECU where TDC is (I thought). I would think that might be the only purpose of the Crankshaft Position Sensor. I would expect the Cam sensor to determine when to fire the coil. On this car, is the Cam sensor integrated into the distributor? -Rod Automotive Network, Inc., Copyright ©2012
