Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Intrepid
Old 01-01-2009, 03:00 PM   #1
jamesrr
jamesrr Normal reputation
oil light on I need Help!!
I know this is the Intrepid forum but since we share the same problem with the 2.7V6 thought I would post here also, the more eyes seeing this the better.
I have an 2002 Stratus 2.7V6 and the oil light comes on at idle when war is warm. I know this engine has a sludge problem, after reading more complaints on the subject my idea of how to deal with this (ignore due to oil level being fine and no noises coming from engine) has changed
1. changed oil pressure sensor no effect
2. ran solvent style engine flush, changed oil no effect
3. ran amsoil flush/ replaced oil with amsoil 10W30
put 4,000 miles on the Amsoil and the oil light appeared to be getting better
didn't come on at all for two weeks. Now it is back on
And as I said before my initial reaction was just to ignore it , but after reading that other owners of this engine had tried this approach. It seems all had the same result a seized engine and very expensive reapir bills.
MY QUESTION
Since my engine has not siezed (yet) what can I do now to prevent this??
1. should I remove valve covers and clean what I can?
2. can the oil pan be removed while the engine is still in the car?
3. is there anything else that can prevent immenent failure
Please help if you can I cannot afford a new car or 6,000 replacement repair bill
Thanks in advance
jamesrr is offline   Reply With Quote
Old 01-01-2009, 08:38 PM   #2
wafrederick
Banned
wafrederick Has more negative feedback than positive
Re: oil light on I need Help!!
The 2.7 also has a very weak bottom end and eats up crankshafts.I have seen this and replace crankshafts in 2.7s with a couple rods that go bad.First thing to do is hook up an oil pressure gauge to see what the oil pressure is.It could be something simple as the oil pressure sending unit..Always break the bolts for the cap holding the cams in,rod cap bolts and the windage tray by hand first using 6 point sockets only.They round off very easily if you do not.
wafrederick is offline   Reply With Quote
Old 01-03-2009, 08:48 PM   #3
midrange
midrange Normal reputation
Send a message via MSN to midrange
CHANGE OIL!
My 2.7 blew tonight!
midrange is offline   Reply With Quote
Bookmarks
Google
Web AF
