92 loyale 4wd won't engage/disengage
nbiehl
12-31-2008, 12:50 PM
Hi,
I have a 92 loyale 4wd wagon with a 5 speed manual transmission.
I have not been able to shift it into 4wd with the push button all winter.
This morning I popped the hood and snugged up all of the vacuum hoses by hand, and the 4wd engaged, but I cannot disengage it with the push button.
I have checked all of the fuses and none of them are blown. I know the button is sending some sort of signal because my radio crackles when I push it.
If anyone has any experience with this problem, or if you just have some ideas of how I can troubleshoot it further, your help would be appreciated.
Thanks
nbiehl
12-31-2008, 01:02 PM
A little additional information:
I recently had the fuel pump and fuel filter replaced by a mechanic. The wagon sat from late July to early November waiting for a repair.
Our first snowstorm was accompanied by several days of subzero temperatures.
I had not tried to engage the 4wd for several months before either of these things happened, so I'm not sure if the problem arose before the repair or the storm.
somick
01-04-2009, 11:03 PM
I have seen same kind of posts at www.ultimatesubaru.org (http://www.ultimatesubaru.org)
Try it. Go to older generation of Subarus.
I hope you will find help there.
Sam
back yard mech
01-10-2009, 10:45 PM
if all four tires arent the same exact size and brand also it could cause your trans. to bind up . could try backing up to release 4wd
