99 F250 Electrical Problem - Transfer Casemt2745 12-30-2008, 08:49 AM I have an erratic electrical problem when putting transfer case in neutral. The door locks cycle on/off repetitively, the door chime rings constantly. I also lost all throttle response, and the dash indicator light for 4x4 status. The transfer case does engage in 4L and 4H positions, and the door lock and chiming problems stop, but still no throttle response or TC status indicator lights. The engine runs fine, and I have not experienced other electrical issues as yet. The vehicle is a '99 F250 SuperDuty w/ 7.3 PowerStroke, 4x4. Any help would be greatly appreciated. Mike :confused: dfordski 01-02-2009, 04:42 AM I'm not familiar w/ 4wd but there has to be a switch that is activated that denotes the neutral shift position is present and somewhere along that circuit, the insulation and very likely insulation on 1 or more other circuit's have become compromised and when the switch closes and the circuit energizes, it simultaneously causes whatever circuit's whose wires are in contact to become energized circuits. If in fact that is the case, You should look for evidence of physical damage that has occurred and probably where multiple wires are being ran bundled. Maybe check locations where work has been done recently. If you pick up a manual it can help you trace the circuit path and I.D. the paths of the other circuits being affected and where their paths might converge. I'm a commercial Machinery Tech and only recently became interested in OBD after my Cat blew up while I was doing 70+mph in heavy traffic 3 weeks after I paid almost 3 C-notes to a state smog diagnostic & repair station that was unable to determine why my truck would not pass smog. However my truck is OBD1 and pre tranny involved. Running scans for stored error codes may not provide any help in your situation but you won't know for sure unless you do. Hope this is of some help, I was thinking any input would be preferable to being left twistin in the wind regarding the problem. Another Mike Automotive Network, Inc., Copyright ©2012
