95 SE car wont go in to gear98camz 12-24-2008, 06:13 PM I have a 95 Probe SE auto and it wont go in to gear and the overdrive light is flashing on the dash, im thinkin the tranny went out and i wanna know if u have to pull the motor to get the tranny out or if u can get it out from the side. Davescort97 12-24-2008, 07:51 PM Welcome to the forum. Check if you have a brake light. It won't come out of park if you don't. I've found that it is easier to pull both and then do your work on it. The tranny can be dropped from underneath if you want to go that route. 98camz 12-31-2008, 10:43 PM yes everything works and it will go into park and drive and everythingbut u step on the gas and it just revs up and the car just creeps along. how hard will it be to drop it from the bottom of the car? 98camz 12-31-2008, 10:44 PM oh also it will go into reverse and go just fine. Davescort97 01-01-2009, 12:57 PM Shouldn't be hard to drop it from the bottom if you can get it high enough on jack stands. 2-3 feet. If it won't go in any forward gearshift lever position, but reverse is OK the problem could be the forward clutch worn, one way clutch worn or the oil flow to the forward clutch being blocked. Automotive Network, Inc., Copyright ©2012
