93 camry high idle
dericks
12-23-2008, 06:07 PM
I have a 93 camry, 5sfe that has suddenly decided to idle at 2500 rpm. Removed throttle body and cleaned it, then replaced Iac. Iac was gummed up and I actually broke it when trying to free it up. So, replaced it. Still have the problem. Runs great, Just too high. Any suggestions where to go from here.
somick
12-24-2008, 11:42 AM
Try to seafoam it. May help.
When I seafoamed my Accord, it pushed all the gunk into the throttle body, which I had to clean afterwords.
Good luck,
Sam
dericks
12-24-2008, 11:49 AM
Do I just run it through the gas?
Mike Gerber
12-24-2008, 03:50 PM
Check for a vacuum leak. The large intake tube leading to the throttle body can also crack and cause a high idle, so inspect that carefully.
Mike
somick
12-24-2008, 05:07 PM
Instructions are on the can. On a warm engine let the vacuum suck it little by little. Let it sit for some time - may be 10-15 minutes. Drive it with different speeds. Be prepared for a cloud of smoke when you first start it.
And do what Mike suggested: check for vacuum leak.
Good luck,
Sam
Brian R.
12-25-2008, 07:26 PM
Test your coolant temperature sensor.
RIP
01-04-2009, 03:50 AM
Ditto. I read a thread not too long ago about the identicle problem. The poor guy must have cleaned and lubed his throttle cable and throttle body 10 times, amongst many other things. Turned out to be the Engine Coolant Temperature (ECT) sensor. We all learned something from that thread.
Found it: http://www.automotiveforums.com/vbulletin/showthread.php?t=909535 We start talking about the ECT at post #35 (of 52 posts) towards the bottom of the first page. It's all good reading. Check to see if you're getting a fault code 22.
Brian R.
01-04-2009, 12:47 PM
Gosh, I wish I had been involved in that thread you cited. I gave up on it once all you guys got involved. I must have gotten busy elsewhere. You have to give LyricLover credit for bringing up the possibility of it being the ECT sensor.
Anyway, notice that the although the continuing problem in that thread was the sensor, it tested ok (although it is not easy to test and the owner may have taken a short-cut of some sort). Another possibility was that the original sensor was good, but disconnecting and reconnecting the new one improved the contact between the sensor and the wiring harness, which was possibly the problem in the first place.
For testing the sensor, refer to page EG1-219 of the '94 Camry manual linked to in the sticky post at the top of this forum. Note that you don't have to remove the sensor to test it. Heat up your engine to operating temperature and shut it off. Remove the contacts from the sensor. Put a standard thermometer or some temperature measuring device against the block near the sensor (wet with oil for better heat transfer). Keep it there until the temperature reading stabilizes. Measure the resistance of the sensor and compare this measurement with the expected reading from the graph. For example if the temperature of the engine is shown to be 140F, then the resistance of the sensor should be about 0.6 kohms. You should probably do this at two different temperatures by measuring it as hot as possible (better for actual use testing) and letting the engine cool down for 15-30 min and retesting at the new temperature.
RIP
01-04-2009, 07:33 PM
The ECT sensor can be had for as little as $20 at Rockauto.com.
jdmccright
01-05-2009, 12:53 PM
You can buy a handheld infrared surface thermometer for $20 at AutoZone (OEM brand). VERY handy when diagnosing cooling problems while keeping hands at safe distances.
I remember that thread...We're all a little wiser after that one. :loser:
