leaking radiator fluid
ebrigham08
12-22-2008, 09:54 PM
my 98 windstar is leaking radiator fluid from a "y" shaped metal pipe coming out of the water pump. i think its a heater hose. i tried to patch it up with waterweld and it worked for a little while then started leaking again. does anyone know where i can get that part? i cant find it anywhere.
tripletdaddy
12-23-2008, 12:15 AM
Dealership and junk yard. Have you tried online? Where is it leaking? Right at the crotch where it splits or at the base? Those metal epoxies work best when you have it pristine, say with brake cleaner, and scuffed up with coarse sandpaper. I wouldn't expect an RTV sealant to take the pressure, though there is an automotive version of GOOP that might work, but again, it needs to be well prepared. If it is leaking where the hose joins it, cut the pipe and connect that or a new hose with hose clamps.
ebrigham08
12-24-2008, 10:54 PM
yeah its leaking right where it splits. and iv looked online for the part but cant find it. i'll probly just go to the dealer ship and find that part. thanks.
tripletdaddy
12-25-2008, 04:58 AM
Hmm, did you try Rockauto.com, Fordparts.com, or some variation of that of online Ford parts dealers? Did you try Napa, Carquest, Federated. I'm not surprised if AA and AZ don't have it.
marknoftall
12-25-2008, 11:24 AM
I had the same problem with my windstar. Had to replace to lines going to the pump, and the pump itself because they were rusted on. Total cost including labour 497.00. Seems like a common problem with Windstars.
