Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Intrepid
Old 12-22-2008, 09:35 AM   #1
tsous
tsous Normal reputation
2002 Dodge Intrepid - my heat stopped working this morning!!!!!
Before I start, I should say that my heat/air conditioning only works on the highest setting, this happened last year.
But I was able to deal with it without getting repairs, but today I was driving to work and my heat stopped blowing air and my air bag light went on at the same time.
Anyone have a similar problem with their car, can I get some input??
tsous is offline   Reply With Quote
Old 12-23-2008, 08:02 AM   #2
tempfixit
tempfixit Normal reputation
Re: 2002 Dodge Intrepid - my heat stopped working this morning!!!!!
Check the blower motor resistor block for continuity, if no continuity replace resistor, located lower right side of HVAC housing in the passenger compartment,
Factory Service Manual Blower Motor Resistor Block testing procedure:
1- Disconnect and isolate the battery negative cable.
2- Unplug the wire harness connector from the blower motor resistor.
3- Check for continuity betweeneach of the blower motor switch input terminals of the resistor and the resistor output terminal. In each case there should be continuity. IIIf OK, repair the wire harness circits between the blower motor switch and the blower motor as required. Of not OK, replace the faulty b;ower motor resistor.
Go to this link, it shows a picture of the resister:
http://www.napaonline.com/MasterPage...Motor+Resistor
Hope this helps
tempfixit is online now   Reply With Quote
Bookmarks
Google
Web AF
