Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Hyundai > Elantra/Avante
Old 12-21-2008, 09:55 PM   #1
mendori1
mendori1 Normal reputation
Frost buid-up inside of windows
What would cause frost to build-up inside the windows?
Anybody have a clue on how to repair it.
Have good heat inside.
It's a 97 Hyundai Elantra GLS
Rick
mendori1 is offline   Reply With Quote
Old 01-06-2009, 06:17 PM   #2
peachferrari
peachferrari Normal reputation
Re: Frost buid-up inside of windows
Usually it happens if you get too much water in the air inside the car. Make sure when running the heat you have it on fresh air (pulling air from outside the car instead of recirculating) and you can also turn the a/c on to help take of the water out of the air (yes, even on hot settings you can use the a/c--it won't get cold don't worry it will just run the a/c condenser).
2005 Tiburon SE 2.7L V6 6sp manual
2008 Santa Fe Limited AWD, 3rd row, Nav
peachferrari is offline   Reply With Quote
Old 01-09-2009, 01:44 PM   #3
josephk300
josephk300 Normal reputation
Things that might be causing the problem:
- Coolant leak in the heater core. Would be pretty evident by the smell, but if its slight, and you have car freshners or other smell wells, could be an issue. Can verify by keeping an eye on the coolant level in the overflow bottle
- Leak coming from window gaskets or other source of outside leak. Check the carpets top side and underneath for dampness.
- Fresh air vent (as addressed by peachferrari). Might want to check the operation of the vent/recirc button to make sure the flap is moving
josephk300 is offline   Reply With Quote
Bookmarks
Google
Web AF
