Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Civic > '92-'95 Civic/EL/Civic Hybrid/Civic GX NGV
Old 12-20-2008, 05:37 AM   #1
dizzle1
dizzle1 Normal reputation
Can you raise the compression ratio on a d15b7
Can you raise the compression ratio on a d15b7?
I was looking at a site called the D series calculator and it seems that if I change the headgasket it will raise compression.
1. So can I use one of these headgaskets? D16Y8 - D16Z6, D16Y8 2 - layer, D17A2 http://www.zealautowerks.com/dseries.html
2. Could I still use 87octane?
3. Just looking for a little more power, but how much I'd like to know?
4. Would this be a bad idea if I turbo it with T3/T4 turbo my max is 8psi?
5. Is the d15b7 a interference engine?
The engine is out of the car and apart I haven't fixed it yet, it was burning oil from worn rings and bad seals.
dizzle1 is offline   Reply With Quote
Old 12-20-2008, 11:21 AM   #2
kris
Off playing with fire.
kris's Avatar
kris Normal reputation
Re: Can you raise the compression ratio on a d15b7
1- Yes, they will work.
2- Yes, this should still be fine.
3- You are moving .5 points of compression. Not really a big jump, and you will probably not notice the difference.
4- Not if you get it tuned.
5- YES
You could put in PM7 or P29 pistons, and bump your compression up over 10:1 also.
kris is offline   Reply With Quote
Old 02-12-2009, 07:22 PM   #3
FrankVtec88
FrankVtec88 Normal reputation
Just mill a couple mm's off the head.
FrankVtec88 is offline   Reply With Quote
Old 02-13-2009, 09:46 PM   #4
PRCIVIC
PRCIVIC Normal reputation
By this date you should have your engine done and running, but if you are still looking for more power, try to get a D16Z6 head, it is about 36cc combustion chamber, yours is 38cc's, lower number means you will have more compression, you will have about 10.1:1 cr, yours is about 9.1:1 and the intake and exhaust valves are about 1mm bigger than D15B7 valves, then get a P28 ecu from e-bay (about $100) that's what we call mini-me, lots of power gain. For this combination i recommend you to use at least 91 oct. gas. Think about it!
PRCIVIC is offline   Reply With Quote
Old 02-23-2009, 11:45 PM   #5
azntech630
azntech630 Normal reputation
if u wanna raise ur compression ratio u need a dome type piston, and the whole valve train. My advice is if this is ur daily car just stick to OEM.
azntech630 is offline   Reply With Quote
Old 02-24-2009, 02:02 AM   #6
kris
kris's Avatar
There are other ways of raising the compression ratio besides these you have listed.
Old 03-04-2009, 11:37 PM   #7
Dweezil6969
Dweezil6969
Y8 HG and enjoy a slight boost for almost no work
`91 CRX DX Kind of moves
`90 CRX Si
Can also be found on:
XceedSpeed.com, MichiganCivics.com, and Zilvia.net
Dweezil6969 is offline   Reply With Quote
Bookmarks
Google
Web AF
