2000 front drive axle joint seal/ lip?parkerb 12-19-2008, 10:50 PM hi all, i'm replacing the hub/ bearing and drive axles. the replacement axles i received have an inch smaller seal on the outer joint- 8" diameter compared to 9" to completely seal the inside of the knuckle. anyone else have experience with this issue before? tripletdaddy 12-21-2008, 03:43 AM Are you saying the 8 inch won't seal because its smaller diameter won't match the inside hub diameter? Sounds like something to bring up with the parts supplier. Automotive Network, Inc., Copyright ©2012
