2001 tahoe 4wheel drive problem
tahoe4x4guy
12-19-2008, 02:15 PM
As it turns out it is not the transfer case that is leaking but the front differential that is leaking. Which is leaking through the drain plug,now i know some people will say to tighten it and i already trued that but it is still leaking.I had posted a thread some time ago and when you put the truck from 2hi to 4 hi you get a sound like you are driving over gravel or road salt and as you turn the truck would slow down almost to a stop but when you put it back into 2hi from 4hi it would drive fine. So would any one have any suggestions on how to fix the leak or fined a replacement plug.
:lol:
Thanks Tahoe4x4guy.
j cAT
12-19-2008, 02:37 PM
:lol:
Thanks Tahoe4x4guy.
the front dif has a drain plug washer...if the washer is cracked it will leak....replace only the washer or get a new drain plug with the magnet that should be in it....
no sealants are used...
do not over tighten...10-15lbs
tahoe4x4guy
12-24-2008, 06:12 PM
washer replaced put in new gear oil and so far so good.
