1976 ford front axleford_1976 12-14-2008, 12:11 AM my front axle on my 1976 ford f150 is pointing upward at the cab. is it made like that or is there something wrong?:headshake Davescort97 12-14-2008, 02:23 AM Truck has twin I beam suspension. Nothing is wrong. ford_1976 12-14-2008, 03:29 PM thanks just got a little worried, thought it was upward to much for a front drive line since i have a lift on the truck. MagicRat 12-14-2008, 04:41 PM i have a lift on the truck. Can you post a picture? Did you buy the truck this way? Sometimes, especially on older trucks, some people made home-made lifts that may not be safe. The twin-I-beam front end on yours often requires dropped beam brackets to work safely when lifted. If someone just installed longer springs, it may not be completely safe. ford_1976 12-14-2008, 05:25 PM Scrapper 12-14-2008, 05:33 PM did you take it to get alighment set after you put lift kit on it? has the king pins have play in them? and if you put bigger springs on that if so thats not good. i would take it to a good alighment man and see what he sais.those springs could pop right out while going down road. how did yo lift the back and is it leval with front? if not you can go to ways like i did i put 160lbs air shocks on the back. i'm not saying it's right but i never had any problems when i owned a 76 150 with 300 six cyl. but again take it to a well known alighnment man just to be safe. Scrapper 12-14-2008, 05:39 PM did you take it to get alighment set after you put lift kit on it? has the king pins have play in them? and if you put bigger springs on that if so thats not good. i would take it to a good alighment man and see what he sais.those springs could pop right out while going down road. how did yo lift the back and is it leval with front? if not you can go to ways like i did i put 160lbs air shocks on the back. i'm not saying it's right but i never had any problems when i owned a 76 150 with 300 six cyl. but again take it to a well known alighnment man just to be safe. ford_1976 12-14-2008, 05:47 PM this how i bought the truck dont know how they lifted. and the guy i bought it from said he didnt know what the guy did when he bought it. MagicRat 12-14-2008, 11:37 PM Okay, those pics make a HUGE difference. That is not a twin - I beam front end (which is a kind of independent front suspension). It looks like a very straightforward solid front axle, and has none of the twin I bean lifting issues. Ford used both systems in their 4wd trucks for many years. I would say it's not the axle that's the concern, but the pinion shaft,(where the front driveshaft should attach), correct? That angle was done to reduce the risk of the front driveshaft binding, with the lift that you have. So long as the front driveshaft turns freely, you should not have a problem for low-speed 4wd driving. High speed, highway driving in 4wd may produce some harmful vibration from the front shaft, due to incorrect U-joint phasing. However, most old, part-time 4wd systems were not built for highway use. So I suggest use 2wd only for higher speed driving. ford_1976 12-15-2008, 12:09 AM ok thanks, i dont have a shaft for it so i guess im good for now haha!!! Automotive Network, Inc., Copyright ©2012
