My sportage is showing code p0171 again. When it first happened, I changed the front O2 sensor,the ignition modules, and got a fuel system treatment. Now the light has returned after 4 mths. Any suggestion on the problem?
It's the 2.0 4 cyl. It doesn't idle rough, I thought it might be that the injectors needed replacing. I'll check for any vaccum to see if that's the problem.
If it is not a vacuum leak, another possibility is the fuel pressure, exhaust leak allowing pure air into the exhaust to the o2 sensor(s), fuel pressure regulator, or a bad MAF sensor.
Recommend getting a Chilton's or Hayne's manual, if you do not already have one, for troubleshooting purposes.
