Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 12-11-2008, 09:33 PM   #1
bigbadbronxy2k5
bigbadbronxy2k5 Normal reputation
Send a message via AIM to bigbadbronxy2k5
SeaFoam?
Ok, I've ben in the car biz for a while, worked on cars since I was 12. Never heard of SeaFoam. What is it? The veritable "engine rebuild in a can" or do the products work they way they say they do? I'm a skeptic as you can tell (Nooo, really, you? lol) and the only additives I've used and trust are Restore and Lucas Products. Anybody feel free to educate me! opcorn: Thanks.
bigbadbronxy2k5 is offline   Reply With Quote
Old 12-11-2008, 11:18 PM   #2
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
jeffcoslacker Normal reputation
Re: SeaFoam?
Works great on stuck lifters (used in oil) or clogged jets/needle valves and injector orifices (used in fuel)...just a really good detergent/solvent.
Won't build compression (unless caused by stuck rings), or slow oil consumption...doesn't claim to either.
Widely used by motorcyclists when you have that trouble with a hung float or stuck float tip after winter storage.
I used it a lot on older Olds and Chevy small blocks with ticky stuck lifters that wouldn't pump up, with good results.
Works good as a fogger to remove carbon from combustion chambers and valve faces too...but then again so does ATF...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
Old 12-12-2008, 03:07 PM   #3
DnaProRacing
DnaProRacing's Avatar
DnaProRacing Normal reputation
Re: SeaFoam?
i used it to remove carbon buildup, inside vac lines, soaking varies parts, etc etc... deep-creep works just as good in the tb, as well as inside/outside the map sensor, egr valve and hose, etc... just a good product...
92 Chevy Lumina Z34 V6 LQ1 Modified 4t60e Wot-Tech Performance Parts (1/4 million Angry Miles)
http://s284.photobucket.com/albums/ll11/DnaProRacing/
DnaProRacing is offline   Reply With Quote
Old 12-12-2008, 03:53 PM   #4
Scrapper
Scrapper Normal reputation
Re: SeaFoam?
that's all i use in all my cars and my bike it is good stuff you can put it in your oil i even use it in lawn mowers every once and awhile. just thought i give you my opinion.
Scrapper is offline   Reply With Quote
Old 12-13-2008, 02:31 PM   #5
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
Blue Bowtie Normal reputation
Re: SeaFoam?
Opinions are like noses - Everybody has one.
In case you were wondering about the science, instead of the opinions, read on.
SeaFoam is basically refinery "waste". About 50% light hydrocarbon oil (pale oil), 30% petroleum naphtha, (charcoal starter fluid/mineral spirits, whatever you want to call it), 10% isopropyl alcohol, and 10% water. With the exception of the alcohol (added to keep the water in an emulsified suspension), the components are the mid- to upper-tier byproducts of hydro cracking useful petroleum products from crude oil. Those that are usually hardest to separate (normally done through a centrifuge) are simply sold as a mixture with some alcohol added to keep it volatile and emulsified.
The alcohol mixes with the water(as does the naphtha to some extent) and the "murky" appearance of the liquid is due to the emulsion created by the water/oil mixture forced into suspension by those solvents.
It ain't rocket science - It's barely science at all. But it was a fair bit of marketing back in the '30s when it was first sold. And it's surely no secret.
And that is exactly what it was originally intended to do, except is was marketed to the outboard marine industry first. The sellers and marketers have lots of suggestions for its use, but only you can decide if you want anything like that in your engine.
It's not much different than WD40 in that regard. The product was originally intended to be a rust preventive, but has been so widely misused that people now think it is a lubricant, penetrant, pancake syrup, and whatever else they want to believe. The marketers certainly aren't going to correct them now (DUH!).
I will tell you that Rochester, Bosch, Hitachi, and other fuel injector manufacturers warn against allowing any water in their systems, so if you were considering putting it in the fuel of your EFI engine, you may want to think a little first.
As for dumping into an intake, plain water injection will do a far superior job of cleaning carbon deposits.
Blue Bowtie is offline   Reply With Quote
Old 12-13-2008, 09:57 PM   #6
jeffcoslacker
Re: SeaFoam?
Yeah but it don't make enough smoke to get the fire dept called to the shop
...empty gun rack.
Old 12-14-2008, 01:30 AM   #7
zuke448
zuke448 Normal reputation
Re: SeaFoam?
With cleaning the upper intakes, i have heard many people compare seafoam to GM's upper intake cleaner. Does anyone know if it is just the top tier pertoleum byproduct? I have a can but just have not had time to use it especially with the fab missouri weather that I have been in. I am very interested because i was planning to do a major clean on my lumina. It just got wires, and is going to get fuel filter tranny filter and maybe plugs (irridium ones) instead of the oem ones to increase some fuel milage. Again I was enlightened by Blue Bowtie's post.
zuke448 is offline   Reply With Quote
Old 12-14-2008, 10:41 PM   #8
bigbadbronxy2k5
Re: SeaFoam?
Thank you Bowtie, I am a facts man myself and what you stated is almost exactly what my research says, as I looked around on the web after I posted. Thanks.
Old 12-15-2008, 10:46 PM   #9
Dodge1063
Dodge1063 Normal reputation
Re: SeaFoam?
Lol I read that about 4 times. That is funny as hell. I have to admit that is a very good point.
Pancake syrup yum!!!!
Dodge1063 is offline   Reply With Quote
Old 12-19-2008, 04:33 PM   #10
DnaProRacing
Re: SeaFoam?
not to be a wiseass "i am from ny tho" but, ive douched my car with seafoam products ever since i bought it. 225,000 miles later - dont think its hurting anything. you can tech talk the shit out of anything, proof to me is hands-on. and getting 1/4 million miles out of a known beater by using seafoam products. well i guess its a good product...
there, now let the beatings begin...
Bookmarks
Google
Web AF
