Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Durango
Old 12-08-2008, 08:11 AM   #1
lancerdad
lancerdad Normal reputation
Send a message via AIM to lancerdad Send a message via Yahoo to lancerdad
2004 Durango windshield washer pump
The washer pump has stopped working (reservoir full) on my 2004 durango. I can't find anything in the user manual on fuse locations. Could it be a fuse? If not is the pump user replaceable? Thanks for any help.
Brian in MI
lancerdad is offline   Reply With Quote
Old 12-09-2008, 01:37 PM   #2
rhandwor
rhandwor Normal reputation
Re: 2004 Durango windshield washer pump
Most pumps are on the bottom of the tank unplug it and use a 12 volt test light and check for power. If you have voltage pull off the hose and make sure it isn't pumping. I've found a blockage is more common than a bad pump. I just pull hose next to nozzle as this is where the majority of blockages occur.
rhandwor is offline   Reply With Quote
Old 12-10-2008, 07:22 AM   #3
DurangoDave
DurangoDave Normal reputation
Yes, it could be a fuse. Just replaced one on my current vehicle (not a Durango so I can't tell you which fuse to check in your case).
Dave
Westminster, MD USA
DurangoDave is offline   Reply With Quote
Bookmarks
Google
Web AF
