ABS light after startingxjbenn05 12-07-2008, 12:18 PM My 96 Tahoe ABS light comes on after starting, fuses check good, parking brake reset several times (no help) and no codes in the computer.. maxwedge 12-07-2008, 02:44 PM Welcome to AF, a std scanner will not access abs codes, it needs to be scanned with the proper scanner to access codes. j cAT 12-08-2008, 11:29 AM My 96 Tahoe ABS light comes on after starting, fuses check good, parking brake reset several times (no help) and no codes in the computer.. I have read many reports that vehicles which had this problem, to check the grounds....a poor ground has caused this problem owners have replaced the abs and found it was a bad ground... the driverside fender/frame area...it is a cheap easy check.. Greenblurr93 12-08-2008, 12:09 PM or air got in the system, ABS modules can be VERY sensitive. Automotive Network, Inc., Copyright ©2012
