Re: Front disc rotor
You won't have to have the rotor pressed off. On older Elantra's, yes, but not the '02. They were a slide on rotor. If you have the screws out, and it's still seized on, then it's just rust buildup. There should be a couple holes in the rotor where you can put a bolt through. This will push the rotor off the hub. If you don't have the correct bolt for this, take a BFH and beat the crap out of it until it comes off. More than likely, you will destroy the rotor in the process.
John Nance, Parts Manager
Bob Rohrman's Indy Hyundai, Suzuki Superstore
7101 East Washington Street
Indianapolis, IN 46219
inss.partsmgr@rohrman.com
1-800-592-5170
317-613-7048
