Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Subaru > Outback
Old 12-04-2008, 08:13 AM   #1
ecamc
ecamc Normal reputation
Send a message via AIM to ecamc
Question 2002 2.5 - mysterious coolant issues
Had the oil changed the other day in my wife's Outback and as we were running errands I noticed the temp gauge running hot, pulled over to check and it immediately went back to normal. Made it home without overheating and checked the coolant resovoir, which was low, so I filled her up. Drove about 120 miles the next day no issues. Checked yesterday and the level was at Min, topped it off to the Max. Ran it last night and when I cranked it up I smelled coolant smell. Checked the fluid again this morning, it's at the Min. Started the car and did not smell the smell. She just called and said when she started it she did.
It has NOT overheated since last week. There are no obvious signs of leakage (no puddles or drips that I can see). Everything feels/runs normal, heat works, etc. I'm keeping a close eye on it, but now I'm beginning to wonder if it's something serious.
Any ideas? I'm hoping something minor, like a leaky hose to the heater box or something.
Thanks,
Ed
ecamc is offline   Reply With Quote
Old 12-22-2008, 09:15 PM   #2
RahX
RahX Normal reputation
Re: 2002 2.5 - mysterious coolant issues
Have someone check the headgaskets.
RahX is offline   Reply With Quote
Old 01-26-2009, 05:03 PM   #3
bebobullet
bebobullet Normal reputation
You have the infamous 2.5. There is an additive that you use in the coolant. I think it's every 36,000 miles. You can only get it at a subaru dealer. I would recommend only using the additive that subaru sells. I've used Bar's leak for aluminum engines and it doesn't work as well.
bebobullet is offline   Reply With Quote
Old 06-01-2009, 10:10 PM   #4
lesanek
lesanek Normal reputation
Unhappy Re: 2002 2.5 - mysterious coolant issues
had the same problem .It was the head gasket ...sorry..
lesanek is offline   Reply With Quote
Old 06-09-2009, 09:21 PM   #5
bertmaster2000
bertmaster2000 Normal reputation
Thumbs down Re: 2002 2.5 - mysterious coolant issues
ditto, i have a 1997 with a 2.5l engine and the headgaskets on it failed at about 120K miles...it's just a given the headgaskets will eventually fail on all subie 2.5s!
bertmaster2000 is offline   Reply With Quote
Old 09-03-2009, 10:05 PM   #6
intel_guy
intel_guy Normal reputation
My 02 Ltd just had the head gasket fail at 190k. Same symptom as you. If you don't want the wife demanding a new car, get it fixed now before it strands her. There is an updated gasket which is supposed to not be prone to fail. I had my trusted mechanic do the gasket, rear main seal, new oil pan, small body work, and new headlight for $1400.
The car runs great again but I think there's either front hubs, tie rods, or mmotor mounts going because I've got vibration during acceleration.
intel_guy is offline   Reply With Quote
Old 09-04-2009, 10:56 PM   #7
RahX
Might have the mechanic check and see if the motor mounts are tight to the cross member and see if they're relatively centered. I've had a few that were loose and 1 that was off center.
Old 11-24-2009, 05:06 AM   #8
4Wheel
AF - Advisor
4Wheel's Avatar
4Wheel Normal reputation
The coolant additive is nothing more than stop leak relabeled. It is used to prevent water leaks to the OUTSIDE and NOT for head gasket failures between the combustion chamber and water passages. Obviously stop leak will not hold up to combustion chamber pressures.
Since it has overheated this is a typical symptom of the 2.5 HG failure.
Another symptom is exhaust in the coolant, this can be "smelled" by sniffing the recovery tank, it should not smell like exhaust, but if it does it is definitely a head gasket failure.
"I cut the header twice, and it's STILL too short!"
4Wheel is offline   Reply With Quote
Bookmarks
Google
Web AF
