ETS light stays on /driving weirdInlovewithmyML 12-03-2008, 01:42 AM Recently I noticed the ETS light go and and stay on. I also noticed my ML driving a little different. It feels as if I have it on off road mode. I do not have much knowledge of how to fix vehicles so please no suggestions on how to fix it. I would like to know if any of you have encountered this problem. I noticed an almost similar thread posted here however, it didn't quite answer my question. I would like to have some knowledge prior to going to a dealership so that I don't get taken advantage of because I am a female. Any help will be appreciated. Thanks. eclass 12-04-2008, 06:01 PM There are sensors for the ETS system that help keep the car under control. If those sensors fail they may cause the car to apply the brakes and do some strange things at different times. Also the car has a sensor for the steering wheel, if that is not working properly you will have the same problem. You will need a factory type scan tool to test the ETS system to find out what is wrong. More than likley the lateral acceleration sensor has failed. It is located just behind the shifter in the center console Automotive Network, Inc., Copyright ©2012
