2003 Taurus Won't pullDon Lott 12-02-2008, 09:54 PM Car won't move forward or backward, fluid is clean and at correct level. No pressure on lines. Help GPFred 12-03-2008, 03:44 PM What do you mean by "won't pull"? Are you trying to tow something? Does it not move when its put in gear? When you put it in gear, can you tell the transmission is shifted into gear? Can you shift thru the other gears and feel any action in the transmission? Does the gear shift move easily, almost too easily? Could the transmission shift cable be broken thus not shifting it in to gear? Can you see the shifter on the top of the transmission move? Good luck. bculwell 12-09-2008, 11:37 PM What do you mean by "won't pull"? Are you trying to tow something? Does it not move when its put in gear? When you put it in gear, can you tell the transmission is shifted into gear? Can you shift thru the other gears and feel any action in the transmission? Does the gear shift move easily, almost too easily? Could the transmission shift cable be broken thus not shifting it in to gear? Can you see the shifter on the top of the transmission move? Good luck. There's no action when you shift the gear. The cable is good and it moves the values in the control box. shorod 12-10-2008, 07:21 AM I've deleted the two other threads you started for this same subject. There's no reason to start a new thread almost daily for the same question. New threads and updates to existing threads will show up in bold for folks when then log in, therefore people will see your threads and respond if they input. Even though the profile for bculwell and Don Lott is slightly different, you two are using the same IP address and asking the same question so I'm treating you as one person. -Rod Automotive Network, Inc., Copyright ©2012
