TPI Torque Specs1986Z28 12-01-2008, 12:14 PM Here are the Gm torque specs for tuned port injection intakes, note some are in ft lbs, and some in in lbs. Manifold to Runner bolts - 25 ft lbs Runner to Manifold bolts - 25 ft lbs Fuel Rail attaching bolts - 15 ft lbs Throttle Body to Plenum bolts - 18 ft lbs Throttle position sensor - 18 in lbs Idle air control valve - 13 ft lbs Throttle body coolant plate - 27 in lbs Throttle body cover plate - 30 in lbs Power brake vacuum fitting - 108 in lbs Fuel line nuts - 20 ft lbs Fuel tube bracket bolts - 25 ft lbs Fuel pressure connection - 115 in lbs Fuel regulator base to rail - 44 in lbs Fuel regulator bracket - 44 in lbs Outlet tube to RH rail retainer - 44 in lbs Automotive Network, Inc., Copyright ©2012
