blinkers wont workRoB51988 11-30-2008, 06:14 PM i adjusted my steering wheel and now all of a sudden my blinkers wont work anymore :eek7: \ any ideas? way2old 11-30-2008, 08:24 PM Please explain a little more. What did you do to "adjust the steering wheel"? Possible you unplugged a connection on the multi-function switch. RoB51988 12-02-2008, 05:20 PM im not sure i just adjusted the wheel down and the blinkers stopped working. i tried to put the wheel back up to where it was but they still didnt work. but now there working and i havent done anything to them. not sure what the problem is way2old 12-02-2008, 06:32 PM Probably a loose connection going to the turn signal(multi-function)switch. The wires will also get pinched occasionaly when the tilt is used. You will need to remove the steering column trim to look at the wiring. Automotive Network, Inc., Copyright ©2012
