3.4 v 3.5 - Differences?
phipps
11-29-2008, 08:11 AM
I used to own a Venture with the 3.4 in it. I had the IMG issue which ended up in a blown head gasket and total top-end rebuild. My wife totaled the van and we now have an Uplander with the 3.5L in it.
Can anyone tell me the differences between the 2 engines? Is the 3.5 simple a rebadged 3.4? It sure looks like the 3.4.
maxwedge
11-29-2008, 09:12 AM
Lots of info out there when using Google, http://en.wikipedia.org/wiki/GM_High_Value_engine
phipps
11-29-2008, 09:20 AM
Thanks for the link. I always forget about wikipedia.
Hopefully GM addressed the IMG issue when they redesigned the engine.
wafrederick
11-29-2008, 01:44 PM
The 3.5 gets better fuel mileage than the 3.4.The 3.5 is in 2005 and up Impalas also.A thinwall 4wd socket for 4x4 trucks can be used for the oil filter socket.My father's friend Rich found this out and it works.
phipps
11-29-2008, 02:45 PM
Good to hear it gets better mileage.
What are you referring to on the oil filter socket? Does this motor have an in-pan oil filter?
wafrederick
11-29-2008, 05:46 PM
It must have an in pan oil filter what I heard from my father's friend Rich.There must be a special oil filter socket out and a thinwall 4wd socket does the same thing
'97ventureowner
11-29-2008, 06:28 PM
The filter for an Uplander with a 3.5 engine is a A C Delco PF47, a standard oil filter. Starting in 2007 the only engine available for the Uplander is a 3.9 (up until then the 3.9 was an optional engine choice.) The 3.9 engine uses a A C Delco PF61. IIRC, the 3.5 is made in 2 locations, Mexico and I believe Canada or US ( someone correct me if I'm wrong :lol: which explains the differences in the ones for the cars, and the other for the light trucks/vans. And the differences in oil filters.
wafrederick
12-01-2008, 06:52 PM
The oil filter location of the 3.5 is in the oil pan and a thinwall 4wdcan be used being careful.The 3.5 is the v6 version of the Oldsmobile Aurora v8.This is what my father's friend Rich told me.I have seen a 3.5
Jrs3800
12-06-2008, 03:59 PM
The 3.5 that you are thinking of was only used for a few years and in the Olds Intrigue and Aurora Only.... No other GM's used this engine... It was a 3.5 Twin Cam Shortstar V6 designed from the Northstar..
The 3.5( 3500 ) they are talking about is a 60* Chevy V6 with the PF47 oil filter on the front bank of the block...
