Re: Passenger side front window
This has been covered before, but old threads are hard to find on this forum.
Anyway, the window regulator is not the old scissors-type, but instead it's a continuous cable driven by an electric motor.
There's a plastic piece at the bottom that the cable slides across. This plastic piece breaks and the window is no longer controlled nor even supported. It lets you pull the window up by hand, but also lets the window 'sag' down if left alone.
Yeah, as jpb says, you need the whole new asssembly.
Not hard to replace.
Good luck.
Dave
Westminster, MD USA
