Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Geo > Metro
Old 11-25-2008, 10:15 PM   #1
Skrilla75
Skrilla75 Normal reputation
Fan Switch
I just bought a 95 Metro and at first the fan only worked in the higest setting now it doesnt work at all when I try it.Is it the fan itself,the switch,a relay?Thanks
Sean
Skrilla75 is offline   Reply With Quote
Old 11-25-2008, 10:44 PM   #2
Scrapper
Scrapper Normal reputation
Re: Fan Switch
i think it's your whole switch that needs replaced because if it would only work on high but then again may be your heater moter. you got three settings on that one switch right?
Scrapper is offline   Reply With Quote
Old 11-26-2008, 02:22 AM   #3
Skrilla75
Re: Fan Switch
I dont even know how many setting there is because the switch doesnt realy click into a position just kind of slides.
Old 11-26-2008, 05:24 AM   #4
Johnny Mullet
Johnny Mullet's Avatar
Johnny Mullet Normal reputation
Send a message via MSN to Johnny Mullet
Re: Fan Switch
The fan switches are known to melt on these cars. Mine melted.
GeoPalooza 2010 will be held July 24th - July 25th
Johnny Mullet is offline   Reply With Quote
Old 11-26-2008, 05:54 AM   #5
Woodie83
Woodie83's Avatar
Woodie83 Normal reputation
Re: Fan Switch
A lot of the time, they just fall apart. The plastic housing is two pieces that snap together, the snappy bits lose their flexibility and fail under the spring tension. In many cases, you can squeeze it back together and smear some epoxy on the sides to hold it together, I've also seen a zip tie as a pemanent solution. Remove the glovebox, reach around there and hold it together while trying it, if the clicks come back and it works, you just need to glue or clamp it.
Woodie
98 Metro and 06 Aerio SX
Woodie83 is offline   Reply With Quote
Old 11-26-2008, 11:45 AM   #6
Skrilla75
Re: Fan Switch
Thanks guys Iam going to try that~If I cant anyone know I good place to source a new switch?
Old 11-26-2008, 02:42 PM   #7
Skrilla75
Re: Fan Switch
Quick update.the switch wasnt making good contact so I just taped it and it added some pressure now she works~
Old 12-06-2008, 07:24 PM   #8
MrPink
MrPink Normal reputation
Re: Fan Switch
Not.... for long. <grin>
-Pink
"Unlike me, many of you have accepted the situation of your imprisonment... and will die here, like rotten cabbages!"
MrPink is offline   Reply With Quote
Bookmarks
Google
Web AF
