1992 1500 Horn Stopped workingschool 11-25-2008, 11:17 AM Just bought a 92 Silverado & the horn stopped working. Could this be a fuse? If so, where is the fuse located? What else could it be? Thanks for your time j cAT 11-26-2008, 09:36 AM Just bought a 92 Silverado & the horn stopped working. Could this be a fuse? If so, where is the fuse located? What else could it be? Thanks for your time to find out for sure get a meter and start looking for a lost feed or a bad ground.....most likely the horn is bad....with meter in ohms scale measure for resistance..should be low 10-20ohms approx..if you get a resistance jump the horn with a fused wire see if it works... if not get another at the scrap yard.. Automotive Network, Inc., Copyright ©2012
