fuse keeps blowingrob_bluhm 11-24-2008, 01:16 PM I have a 2000 Ford F150 and the #15 fuse keeps blowing even with the key off. It say thet it is for my stop lamp switch ( spped control, brake shift interlock), GEM module, and RABS module. Any help is appereated discnik 11-24-2008, 10:47 PM Did this start happening after wet weather ? Ihave read several instances where water get in past the windshield weather stripping and into the fuse block. Fora 11-25-2008, 05:39 PM If it's the fuse for the cruise control, I'd quit replacing the fuse and have a dealer's shop check the cruise control pressure switch. My 2000 F150 caught fire and the source was the cruise control pressure switch located on the master cylinder. There's a recall on this part. Do not park in a garage or under a carport until you've ruled out the cruise control issue. Mine caught fire in a parking lot. If it had been at night, the house would have burned. -- Rick Davescort97 11-27-2008, 02:15 AM Take it to an auto electrical shop. They have the equipment to locate the ground out on a hot wire. But, if it were me I would replace the brake light switch on the brake pedal. I's the only moving part in the brake light system. It is grounding a hot wire out blowing the fuse. Automotive Network, Inc., Copyright ©2012
