Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Mazda > MX-5/ Miata
Old 11-22-2008, 08:36 PM   #1
99 Mazda Roadster
99 Mazda Roadster Normal reputation
Vaiable valve timing control sensor or camshaft position sensor?
I have a 99 Miata 1800cc. My mechanic told me that I need a variable valve timing control sensor. Tried looking this up on various websites, but i can't find it. Does anyone know if the variable valve timing control sensor is the same thing as the camshaft position sensor?
99 Mazda Roadster is offline   Reply With Quote
Old 07-09-2009, 11:54 PM   #2
CaseyJones797
CaseyJones797 Normal reputation
Re: Vaiable valve timing control sensor or camshaft position sensor?
VVT did not start appearing until 2001 as I recall. 1999 cars used cam position sensors (a lot cheaper to replace!). Trust me, I have a 1999 Miata that I have modified a little and enjoy a lot. Your mechanic is either an idiot or a liar and is trying to stick you with an expensive fake repair.
The CPS is VERY easy to replace and is very accessible. Right on the left front of the valve cover, one bolt holds it on and the wiring plug clips on and off easily. No adjustment on a '99 car, just go to Advance or AutoZone and get a replacement. It's a two minute job.
They don't fail often. Take it off and use some spray throttle body cleaner (an aerosol can also from Advance\AutoZone) and clean off the end that sticks in the valve cover. That might take care of your problem.
Give me a chance to prove that money can't make me happy...
Currently 2009 Charger R/T with all the performance options and nearly everything else.
1968 B5 blue R/T, 440 4 speed, Super Drag Pack, radio delete, no p\s, numbers matching. I miss her....
CaseyJones797 is offline   Reply With Quote
Bookmarks
Google
Web AF
