Washer Fluid Hardly Comes out... 96 Taurus
Please_Help_Me
11-22-2008, 07:07 PM
:confused: :confused: :confused: :confused: :confused: :confused:
So my fluid IS coming out but it doesnt hit my windshield. I did the whole puttin the pin in the holes and NOTHING!!!! Its drivin me nuts, it gets worse and worse every time i try to use it.
Can anyone help me
shorod
11-22-2008, 11:45 PM
Welcome to the forum!
Does the fluid come out with good force, it just isn't aimed properly, or is the pressure low?
If the aiming is the problem, then re-aim the nozzles. If the pressure is low, then check the hoses for restrictions. If no restrictions, you may be due for a new pump. You do have plenty of washer fluid in the reservoir, correct, and the fluid is appropriate washer fluid and not mostly water?
There may be a check valve in the hoses too, so you shouldn't try to use forced air to blow through the hoses backwards.
-Rod
