Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Monte Carlo
Old 11-22-2008, 06:49 PM   #1
woodturner2
woodturner2 Normal reputation
Question 01 Monte Carlo temp guage quits working
My temperature guage keeps going to 0 and the engine fans come on. I have checked and I have 5 volts to the sensor and I have checked the ohms resistance of the sensor and it is good. What else can I check?
woodturner2 is offline   Reply With Quote
Old 11-23-2008, 05:33 PM   #2
woodturner2
Re: 01 Monte Carlo temp guage quits working
This problem started after I put a overflo tank on the car it had a bolt in the hose with a clamp on it. After the guage drops it sets the code and once I erase the code the guage pops back up. Mabe I have a air pocket I cant get rid of.
Old 11-25-2008, 03:20 AM   #3
mazingo
mazingo Normal reputation
Maybe some one will post an answer to your problem. I have a 2001 malibu that does the same thing. It will actually fix itself for a while then it will quit working again, seems to be worse when its cold weather. It has been doing it for over two years. I could live with it but it really makes my MPG suck and runs both cooling fans continuosly. Good luck.
mazingo is offline   Reply With Quote
Old 11-25-2008, 10:37 AM   #4
woodturner2
It was the thermostat. I was told that when the pcm does not recieve the right temp signal it defaults the guage to zero and turns the engine fans on and that is why you are getting the bad mileage is because the pcm controls all of the engine adjustments do to what it thinks the engine temp is.
Bookmarks
Google
Web AF
