'02 Taurus ball joint wear.....
Anaudiophile
11-22-2008, 12:05 PM
Can someone tell me the allowable amount of play in the front lower ball joints on these cars? I have a small amount on one side and a considerable amount on the other. I'm sure quite a few thousandths of an inch is ok, but just wondering what the exact specs. are !
shorod
11-22-2008, 11:41 PM
Per the factory service manual:
Ball Joint Radial Play
Ball joint — maximum 0.75 mm (0.030 inch)
-Rod
tripletdaddy
11-23-2008, 02:56 AM
Well, you did give him the answer he wanted, Rod, but what's the method to do that with any accuracy? :shakehead
Do you know Rod?
I'm really surprised the spec is really that large of an allowance. I'd bet the state inspectors here in Va and a front end tech would reject it at that amount. The inspector pretty much doesn't want to feel any movement in the suspension and bearings by shaking and yanking on the tires while elevated. Likewise, when you have the front end aligned, any movement is not allowed to perform such. This problem is both detectable by the computerized system and manually as per above. So, for me, I do the manual "shakedown" both as a preventative measure and to diagnose an existing problem typically indicated by rattling, creaking and other noises. If you are suspicious of something, just replace it. You'll probably need to anyway since you will want to perform an alignment after replacing even just the one. The expense of the alignment alone might be enough motivation alone to replace both so as to not to redo the alignment after replacing it at another time.
shorod
11-23-2008, 12:09 PM
I don't know how you'd make that measurement with accuracy. If I notice any play in a balljoint/tie rod end, I'll comdemn it and suggest it be replaced.
-Rod
Anaudiophile
11-23-2008, 01:35 PM
Thanks for the info.
