clicking noise coming from under dash on 2005 chevy equinox L Sjohn j toomey 11-21-2008, 05:33 PM We have 2005 equinox L S and have a clicking noise coming from under the dash drivers side. It sounds like a flasher/ blinker and gos off after about 5 minutes and comes back on sometimes. Any ideas before I rip the dash off. Thanks Jack firemedic110 11-24-2009, 05:05 PM I am having the same problem. Anyone know what causes this? john j toomey 11-24-2009, 05:51 PM Did you put a remote starter in yours. Because we did and the security light was on because for some reason it messes it up when you install one. We brought it to a place and they installed a by pass module and they reset the computer. It was like a $130.00 tho! That fixed it. I think you are supposed to put this unit in from the begining of having a remote started put in. My daughter had one of her friends do it and they didn't put one in. Hope this helps you Jack firemedic110 12-02-2009, 11:57 AM No, there are no aftermarket installs on this Equinox. I had to replace the EGR valve recently and subsequently had the PCM updated/reset. Hopefully the reset corrects the problem; I haven't heard it since. Thanks for the reply! tech JK 12-12-2009, 01:53 AM If you also heater or A/C problems, then Sounds like typical temperature door has broken int your Chevy Equinox. It is buried inside the dash. When it breaks, you have no heat. Not electrical or any other problem. This repair takes a good 8 hours to replace the $30 door. Entire dash, carrier, and HVAC case has to come out and disasemble. Also does this on the Pontiac Torrent. Equinox Torrent Heater Door Problem Repair Pictures (http://www.greatautohelp.com/pontiacanswers/My-2006-Torrent-No-Heat.html) Automotive Network, Inc., Copyright ©2012
