need help!
michaelrichardson@
11-21-2008, 03:57 PM
98 cirrus. I replaced the water pump/timing belt/fan belts/ Now when the power steering fluid warms up it bubbles out of the reservoir
lord Kelvin
11-24-2008, 10:17 PM
Wow, never heard of that. Are you saying the fluid is getting aerated. When you look at the fluid, is it clear? I've seen this happen on a transmission when a seal went bad, causing the pump to suck air and churn it into the fluid.
Regarding the timing-chain & water-pump, I'll be doing that on my 99 2.5L in the spring. Did you have any difficulty, or have any tips to share?
ADDED INFO:
Came across a post elsewhere where mixing different type p/s fluids caused a frothing problem. You might want to drain & refill the p/s fluid to eliminate that possibility.
Here is the link: http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1292650
