99 silverado idles up and down in cold weather
hempdogg
11-20-2008, 08:57 AM
i have a 99 silverado it runs fine in the summer but when its cold it idles up and down in park and in drive it dosent go a way till the weather get warn agian. any ideas
j cAT
11-20-2008, 10:48 AM
is the idle problem continuous??? when cold..or only until engine is at normal temp ??
what is the spread hi/lo RPM's...
the IAC and throttle body should be cleaned periodically...have you ever done this..?
Check PCV/hoses and other sources of vacuum leaks and/or air duct leaks..
ECT may be out of range....
