Oil level sensorVince1057 11-19-2008, 09:33 PM Check engine oil level light just came on on my 2000 Tahoe 4x4 4.8l. I checked the level and it is at the line (full upper line). Could this be a problem with the oil level sensor? I just had my started replaced. Is this sensor near the starter and may have been unplugged? Is it safe to drive, the oil pressure is reading normal? Thanks 2000CAYukon 11-20-2008, 12:20 AM It is fine to drive since the pressure is good and you know the level is fine. The sensor is in the side of the oil pan but I am not sure what side and too lazy to look on mine; however, most likely the sensor was unplugged (or damaged) when the starter was installed. //2000CAYukon Automotive Network, Inc., Copyright ©2012
