Lets discuss Ethanol
Wags391
11-19-2008, 06:11 PM
I have recently moved to Florida and I have found out that FL has a mandate that ALL gasoline must be blended with 10% ethanol. Which sucks because it makes my car run rough and, as all studies have shown, significantly lowers mileage. So, two things: What are some things I could do to counteract the effects of ethanol on mileage? Two, fight the blending trend!! It's bad for older vehicles. Find out if your state has mandates and help get them overturned. More importantly, what can I do? I have no access to any ethanol free gas.
ericn1300
11-19-2008, 06:45 PM
Besides the drop in mileage my Bravada vapor locked this summer a few times from using ethanol. Shut it down hot and the fuel lines vapor locked, had to wait until it cooled down before it would restart. My Pontiac keeps throwing emmision trouble codes when using ethanol blends.
Our state AAA website lists stations that still have ethanol free gasoline but they are getting harder to find. Go to AAA.com and to the bottom of the page to put in your zip code and find your state club's web site.
Leeann94astro
11-20-2008, 09:39 AM
^ Florida, like Maryland, has mandated that ALL gasoline sold in the state be ethanol blended. That means he has to go out of state to get better gas, as do I. Pennsylvania has no such mandate, but it is getting harder and harder to find stations that sell non-ethanol blended.
Which sucks because none of my vehicles like the crap at all. And, to boot, we have emissions testing. And all my vehicles, though they still pass, are MUCH closer to the limits on ethanol crap. And this is supposed to be better for the environment....
Blue Bowtie
11-21-2008, 11:06 PM
I've been using E-10 since 1976. I've had no such problems in any of about 22 vehicles which I've owned (and can count) since then (7 of which I still own). Several of those were carbureted, with both "stupid" carburetors and feedbacks (like E4MEs), and a good number of those were/are injected. The 355 in my '50 pickup made 423HP at the crank on 93 octane E-10. If you aren't getting power or mileage, there is another reason. In my "limited" experience, mileage suffers no penalty until the amount of ethanol exceeds 22-25%, at which point it starts to drop if you haven't adjusted timing, coolant temperature, and compression to compensate.
Stop reading urban legend and start collecting real, empirical data. I keep a running fuel mileage log on all my DD vehicles, and I notice no drop in mileage from E-10 up to about E-30. Running E-85 in the summer only costs me about 11% in mileage, but when the price of E-85 is $2.25 and gasoline is $4.25, it's still a bargain to use the E-85. Perform the math based upon reality and hard data, and you can see the results for yourself.
As for your specific problem,. I'm thinking that ethanol is not the issue. Gasoline evaporates at a much lower temperature than ethanol, and with a much higher vapor pressure (which is a big reason that high ethanol percentage fuel suck in colder weather). If the fuel lines actually vapor locked, it's because gasoline percolated/boiled, not ethanol.
Moreover, if you understand your fuel system, you would also understand how that cannot happen on a modern EFI system. Fuel is pressurized at the source and excess liquid and any vapors are returned to the tank through the regulator and second line. The fuel pump is IN the tank, so please explain to me how the lines can vapor lock. I'm all ears...
Chris Stewart
11-22-2008, 09:31 PM
Alky is here to stay and it doesn't light off as easily as gasoline and given the lower temperatures in Colorado...the temperatures are likely a factor.
Many NHRA Top Alcohol Funny Cars are started on gasoline.
If fuel squirt is maxed due to lower fuel pressures of a worn fuel pump, a lean mix and cold too could get pretty miserable. Maybe a shot of compression with more ignition timing advance (advance the 4.3 distributor a few degrees) could recover some drivability.
Maybe a shot of propane to get the engine started???
Blue Bowtie
11-22-2008, 10:51 PM
Starting is a problem once the temperature is in the 20s (is 15º here now). Even though the actual ethanol percentage is dropped by the blenders in winter months to as low as 50%, starting is harder. The ethanol just doesn't vaporize as easily, thus the point about vapor lock.
I can get away with 25% ethanol all winter long and have easy starts. Above that, it takes a little cranking compression heating to get things moving. Once it is going, there are not a lot of problems other than more moisture in the crankcase, requiring complete warmup or more frequent oil changes.
wafrederick
11-23-2008, 01:06 PM
There were plants in Michigan,now shut down making Ethanol,too expensive.Plus it raises the price of Corn which is bad.The IRL uses Ethanol for race fuel.The fuel pumps for flex fuel vehicles are more money if one goes out.
ericn1300
11-23-2008, 07:37 PM
Like the laws of physics? ethanol has less energy content by volume.
expect a similar decrease in gas mileage in any current FFV. That’s because ethanol has a lower energy content than gasoline: 75,670 British thermal units per gallon instead of 115,400, according to the National Highway Traffic Safety Administration. So you have to burn more fuel to generate the same amount of energy.
http://www.tpub.com/content/altfuels07/4788/47880142.htm
When I speak of vapor lock it is at high temperatures. Gasoline is more volatile than alcohol at low temps but the inverse is true at high temps. Low temps do inhibit the evaporation of alcohol and thats why I keep my Vodka chilled, but at high temps the addition of alcohol increase the vapor pressure in a fuel system.
As long as the engine and fuel pump are running, vapor lock can not occur. The problem came when shutting down the vehicle for a short period when hot and the ethanol vapor locked the fuel lines under the hood during the "heat soak". Nothing much to do but prop the hood open and wait. Happened a few times last summer.
The relatively low boiling points and high vapor pressures of methyl and ethyl alcohol indicate that vapor lock could be a serious problem, particularly at high altitudes on warm summer days.
http://www.ext.colostate.edu/Pubs/farmmgt/05010.html
Chris Stewart
11-25-2008, 08:34 PM
How about if you turn the keyswitch on until the fuel pump quits running then turn it off then back on to get multiple fuel pump runs to maybe push the gasses out of the system before starting? It helps get mine started because of low pump pressure...I gotta replace that thing...lol
ericn1300
11-26-2008, 09:23 PM
Isn't that the same as repeated start attempts? Didn't work for me. I tried bleeding down the pressure at the test valve too, no go. Maybe bleeding off the the pressure on the return side might help, but no valve on that side, any ideas on how to do that?
Blue Bowtie
11-27-2008, 01:02 PM
Well, that's at least half the science. Granted, ethanol by itself has less HEAT energy than refined gasoline. That doesn't mean less energy. Hydrazine has far less heat energy than gasoline, but you don't see gasoline being used as a rocket fuel. Kerosene (diesel) has more heat energy than gasoline, so why aren't you burning that in your car? Coal has even more heat energy. Why aren't the Consumer Reports "experts" using coal in their cars?
When I sat through physics and chemistry classes, I was taught that heat is only a small fraction of the equation. When you dust off your old physics books and re-read the chapters on Boyle, Charles, and Dalton's laws, you might have a better grasp of the energy produced by the creation of more moles of resultant gasses with ethanol combustion than with gasoline combustion. Pressure by heat is only a fraction of that pressure.
Being educated in Big Ten schools (two of them) there is little doubt that site was produced with the "assistance" of the liberal arts and journalism departments of a PAC 10 school.
Before you try to defend them, remember that these are the same people who handed us the likes of Nancy Pelosi nd Harry Reid. 'Nuff said?
Blue Bowtie
11-27-2008, 01:15 PM
But compare that to the vapor pressure and boiling points for gasoline. The link you provided clearly shows the vapor pressures for pure fuels, but rather conveniently neglects to list the details for commonly available blended gasoline, which is what most of you are using. It has a vapor pressure almost 50% higher than ethanol. Get that data in your hands, then tell me which one will vaporize with lower input heat and impart more vapor pressure on the closed system.
The universities of Iowa, Indiana, and Illinois have a lot more empirical data on ethanol fuels than Colorado, dating back to the mid-1970s. Colorado, despite their beautiful landscapes and friendly population, just doesn't have any history with grain ethanol.
Blue Bowtie
11-27-2008, 01:21 PM
Yes. Make sure the pump is capable of delivering fuel at a significantly higher pressure than the setting of the FPR, and vapors will be purged on the first two-second prime cycle of the fuel pump (just the way the factory designed it).
If the pump is weak, there is not much else to be done other than to relieve pressure and hope the pump can push some liquid fuel through the line faster than it can explode into vapor in the hot lines. you can insulate/isolate the fuel lines with heat shielding if the problem becomes more than a periodic nuisance.
Strange that you would experience this with ethanol, but at 100ºF, I have no such problems on any vehicle, including the potentially worst offender, a CPI system in a van, where all the heat is contains in one, compact area.
Wags391
11-28-2008, 03:52 PM
So, to get back to my original question... Are there any options for a vehicle running on E10 that shouldn't be?
Chris Stewart
11-28-2008, 09:22 PM
Just remembering some things...alky "burns" cool. The alky dragsters & funny cars do long burnouts, back up slow, take a long time to stage then jump on the throttle, slipping clutches while holding a death grip on the brakes trying to build up extra heat before launching. You don't hear of them torching pistons either.
Alky, like many other liquids, boil at lower temperatures as atmospheric pressure decreases...like on a Colorado mountain. It could be "fizzing" the gasoline.
The late great Smokey Yunick built a motor for the Pike's Peak race with instructions not to fire the engine until you got to the race area...that mill musta had some real compression.
Now this may have an impact on the O2 sensor too since it's a thermocouple and needs a good deal of heat to generate the millivolt signal which the computer uses to determine injector squirt.
Blue Bowtie
11-28-2008, 09:29 PM
E-10 should not be a problem. If the engine is now running rough, it is likely due to the ethanol cleaning out the fuel system. The sediments, rust particles, additive deposits, and other random contaminants should be captured by the fuel filter. However, once the filter is slugged, or if it is damaged or inadequate to filter fine particulates, these contaminants can reach the fuel injectors and clog the inlet screens, or worse, clog the injector pintles or spray tips/orifices. I'd suspect the rough running is due to a fuel delivery problem, and not the fuel itself. If the problem persists after several tankfuls of fuel, the fuel system may need to be checked.
Chris Stewart
11-28-2008, 10:25 PM
Alky's not a cleaner. It does attract water which will corrode your steel and aluminum parts.
ericn1300
11-28-2008, 10:36 PM
LOL, hydrazine and coal are solid fuels and very hard to to run thru my 16 year old Bravada without some major modifications. Kerosene does have more energy than gasoline but I can't use that either. Stick to the thesis of the thread: Ethanol blends vs Gasoline.
I've been there, seen the beautiful landscapes and the natives were quite friendly, with the exception of my ex-wife, but I would love to see the data excluding or over riding their research, have any links with empirical data?
If your idea of academic excellence is based on the athletic conference your school was in then it's no surprise you just ”sat through physics and chemistry classes”
Nancy and Harry actually fought the farm lobbyists that promoted the tax breaks the Republicans so greedily applied for.
ericn1300
11-28-2008, 10:56 PM
If the vapor pressure of the blockage is higher than the fuel pump pressure and the blockage is at a height greater than the fuel pressure relief valve (FPR) your theory goes down the drain. Vapors rise and don't go down hill until forced down. 60 lbs of fuel pressure ain't going to do it.
Wags391
11-28-2008, 10:57 PM
Wow. This thread is getting political rather than helping. Come on guys, any ideas besides higher octane gas?
ericn1300
11-28-2008, 11:07 PM
Actually, Ethanol is a higher octane than un-blended gas but that's a whole 'nuther discussion. The only thing to do about it is to call or write all your elected officials and more importantly contact your state AAA club. They lobby on your behalf and if they get enough complaints they will pressure the pol cats on your behalf
Chris Stewart
11-29-2008, 11:22 AM
Maybe the mix is better now...I've read some stories where too much alky was put in gasoline causing problems when it was first put to use.
Just to be fair, all my gassers did fine this summer except for the garden tractor which acted like it was running lean but recovered when I pulled the choke a little...most likely the carburetor needs taking apart and cleaned. The weedeater did fine also.
Blue Bowtie
11-30-2008, 09:19 AM
Oh, c'mon... You're not trying hard enough. ;) (Actually, hydrazine is a liquid, but we get the idea.) The point was, and remains, that Btu energy is NOT the whole story, despite what Consumer Reports might proclaim.
Sorry you found one of the less-friendly natives. I'm sure they are the exception, and are not limited to Colorado. At least you survived with your sanity. I'll try to compile what I have gathered and forward it if you are really interested. I did quite a bit of research on the topic about four years ago when I converted my half-truck to running E-85. Colorado was a good on-line resource, but by no means the ultimate authority. I'll have to scan what I've gathered. I should have done that a long time ago, since this topic arises frequently, and is likely to only become more relevant as everyone else catches up to ethanol blends. Remember, I've been doing this in a practical sense since 1976 with no serious trouble in any vehicle. I have had some initial problems, such as the OP is experiencing. Most of that was with carbureted engines, but even those came around, and were ultimately even easier to adjust for the changes.
Nice catch, but even through osmosis I retained a few things. FWIW, no one from the Big 10 should be bragging too much about their athletics programs. I was speaking strictly about science and academics.
That's not so much of an argument as it is more evidence of them fighting a losing battle - Something for which they have demonstrated acuity. Never forget that our new "Change" president-elect is heavily vested in renewable energy (read "ethanol") and makes his home in Chicago. Whether or not you agree or subscribe to the science, it isn't going away any time soon.
As for the previous comment regarding food prices being escalated by the use of grains for fuel (I'm not sure who posted it), remember that a $4.00 box of corn flakes contains a whopping total of 14¢ worth of corn. The rest is labor, operating costs, transportation, and marketing (or greed). That was the value when corn was $4.35/bushel. and since it is now back to under $3.50, there is even less cost in that box. Did you see the prices lowered by 25%? Didn't think so. For those worried about food prices, do some more research. Given the amount of mash corn grown (which can't be used for much else) versus feed corn, the volume of feed corn hasn't been reduced enough to drive prices one way or the other. CBOT prices have been driven by the anticipated energy prices required to dry, deliver, and process grains, and not the availability of grains themselves. Stop listening to politicians and their hip-pocket news media, and start researching.
Diagram that concept and observe it. The relief line is open all the way back to the tank. Once liquid pressure is greater than the relief valve (FPR) setting, anything in the line will be pushed back to the tank, whether it is a vapor, gas, liquid, or solid (small enough to pass the regulator disc valve). The return line does indeed travel back downward to the tank, but only a total of about 20". That only adds about 0.65 PSI to the pressure required to flood the line with fuel. A sequential CPI system pump should be able to dead-head at least 71 PSIG, which is more than adequate to purge the lines. Even though a vehicle will run with only 61 PSIG, the pump should perform better (as it is designed to). If you are experiencing vapor lock (and it seems that you may well be) I'd test the fuel pressure with the return line closed to measure peak pump pressure. I understand that a small volume of fuel in the injector pod may turn to vapor, but the design volume of the pump (minimum 4 LPM) should be able to displace that easily on a prime cycle.
Blue Bowtie
11-30-2008, 09:30 AM
Yes, about 4-5 posts ago.
Have you tested fuel pressure? Checked/changed the fuel filter? As previously mentioned, the ethanol will start cleaning out all manner of junk from the tank and lines. The filter is your first line of defense. Since the vehicle has evidently not previously used ethanol blends, this process will continue until the system is clean. Get familiar with the filter change procedure, since you might be doing it more than once until the system is clean.
Don't blame the fuel. It's only cleaning out what the other fuel left in there. You should see what happens to a 1950s or 1960s vehicle when ethanol is first run through it. Been there.
If there is already sediment in the injector pod inlet screens, it may be time to pull the pod and clean it. If you have to go that far, be absolutely certain you have a good filter installed, since you probably don't want to be cleaning the injector pod again.
Another thing to remember is that alcohols are hygroscopic, meaning that they have an affinity for water. Given the relatively high humidity present in Florida, that means that some water will be more likely found in the fuel. Fuel tanks are vented, and some of that water will enter the fuel as it is stored. The only thing you can do to counteract that is to purchase fuel where there is a lot of traffic, and the fuel will theoretically have less time in the tanks to absorb water.
Another important step is to be sure your fuel system is sealed. If you have an unsealed system, the PCM should be setting an EVAP related error code.
ericn1300
11-30-2008, 07:46 PM
Bowtie is correct. Ethanol will transport water and water soluble debris thru the engine that would otherwise be left behind. The water carried by the ethanol will also tend to blast out some of the carbon build up, a notorious problem on the 4.3 engine. Keep the EGR valve clean by installing a screened gasket to block the larger chunks that bind off the pintle.
