95 gmc jimmy gets fuel but no spark - plz helpdetorra 11-17-2008, 09:11 PM just put a motor in, went to turn it over with all sensors replaced and got no spark, replaced coil, ignition module, cam sensor, crank sensor, tested all wires for cont. - went by the book and looked to see if there was a pulse signal, no pulse signal but each sensor is getting the proper voltage. i dont know what to do now maxwedge 11-18-2008, 04:59 PM Did it run before or did this happen during the engine work? detorra 11-23-2008, 02:58 PM Did it run before or did this happen during the engine work? i got it fixed, if the timing chain is off just a hair or loose just a hair the motor will not start in these trucks maxwedge 11-23-2008, 03:57 PM Yep, basics as usual! Automotive Network, Inc., Copyright ©2012
