Clio Maxim S 'R' reg dash lights
Google
Web AF
nicktmg
11-17-2008, 05:46 PM
Anyone help me with how to replace bulbs in the dash ?
No lights behind part of the speedo and fuel gauge.
Any help much appreciated,
Thanks,
Nick
JamesP4590
11-28-2008, 03:51 PM
Hi Nick.
You need some 2 different size torque drivers. Remove the 4 bolts along the bottom of the windscreen & one at each end next to the wing mirrors! then remove the plastic cover under the stearing wheel, both parts. The main dash bit is held by four bolt. Two which are easy to get to from the top. 2 from under the steering wheel.
Then carefully remove the electric sockets, being very careful with the flexi circuit menbrain (can't spell). The speedo cable should pull out. The you can replace the bulbs! Should take about 30-40 minutes. But that was on the older 'R' plate grande that i had. The last of the old shape with the third brake light!
Safe driving
James
Google
Web AF
