Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Taurus/Taurus Wagon
Old 11-15-2008, 10:10 PM   #1
RELL1274
RELL1274 Normal reputation
Rod I Need Your Help Again
I Need A Pdf File Or Some Type Of Picture Of Where The Pcm Is Located On The 97 Taurus Please Help Me If You Can
RELL1274 is offline   Reply With Quote
Old 11-15-2008, 10:25 PM   #2
shorod
Taurus Guy
shorod's Avatar
shorod Normal reputation
Re: Rod I Need Your Help Again
From the factory service manual, below are the steps to remove the PCM. In the diagram below, the PCM is item 7.
Removal
1. Disconnect battery ground cable (14301). Refer to «Section 14-01».
2. Remove cowl deflector.
3. Remove screw securing the ground cable of the engine control sensor wiring (12A581) to the dash panel (01610).
4. Loosen engine control sensor wiring to PCM connector retainer bolt.
5. Remove engine control sensor wiring from PCM (12A650).
6. Remove retaining nuts and powertrain control module insulator from dash panel.
7. Remove powertrain control module.
shorod is offline   Reply With Quote
Old 11-16-2008, 04:14 AM   #3
RELL1274
Where Is The Pcm Located I Cant Find It
Old 11-16-2008, 11:20 AM   #4
way2old
TOKEN HILLBILLY
way2old's Avatar
way2old Normal reputation
Look under the hood on center/passenger side. You will see a large wiring connection. This will have somewhere from 60 to 120 wires in it. This is the wiring to the PCM. Remove the wiring connector and there are 2 little bolts that hold the PCM in place.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
way2old is offline   Reply With Quote
Bookmarks
Google
Web AF
