New member old questionsRedfrog 11-15-2008, 12:52 PM Hello all. I'm new to this forum annd have a few questions. I've tried searching the answers and had no luck. I have a 2000 Gmc sierra 4X4.with a 5.3 L engine. While driving on the highway, my oil pressure guage dropped to zero. I pulled over and shut the engine off. I checked for obvious visible problems and could find nothing. I started the engine and everything worked as normal. Oil pressure was back up. I have both guages and idiot lights. There was no unusual noise from the engine. I continued drivine for another 40 minutes when it happened again. This time I pulled over and shut the engine off. Again a visual showed nothing. I restarted and the oil pressure came to normal but the engine lifters were noisy. I shut the engine again. I trailered the truck home and it now runs with normal oil pressure and slight lifter noise. I have had it idle for an extended time with no change. The truck has 415 thousand KMs. on it. Any ideas?? I have acces to a 5.3L engine from the same model truck, but a year older. Will they swap?? Thanks maxwedge 11-15-2008, 01:06 PM Welcome to AF, get a known accurate oil pressure gage tapped into the engine and see what you have. Automotive Network, Inc., Copyright ©2012
