Re: Need Your Help Rod again and again as usual
I don't know exactly where it is for this car, but I can tell you how to find it. Look for a metal pipe coming off the exhaust (most likely the manifold) and going up to the intake manifold or possibly the throttle body. There will be a valve close to where it connects to the intake. That will be the EGR valve. If it has a vacuum tube coming off it, it will go to a solenoid that controls the valve. If it has wires connected to it, it's solenoid operated.
Hope this helps.
