03 tahoe inside door courtesy lightlou S. 11-14-2008, 07:58 AM Does anybody have a tip on how to remove the lens so the light bulb can be changed on the inside door panel? Thanks in advance. jthomp23777 11-14-2008, 10:25 AM Well the 03 should be similiar to my 2001.Need to remove inside door panel. Easy enough, remove panel screws and plastic panel behind door handle.Pop off automatic slide lock,note position of locking arm that fits into slide lock.Lift up panel straight up. This should gice you room to reach in. Bulb is twist locked into lens housing.... Automotive Network, Inc., Copyright ©2012
