Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Tahoe
Old 11-14-2008, 05:44 AM   #1
jsetche
jsetche Normal reputation
1998 Tahoe Fog Light Switch
I bought the delco fog light switch for my tahoe to give it the "factory" look. Problem is that I thought the wiring harness would be in the dash but I cannot find it. Making my own wiring connections is an option, but does anyone have the schematics for the switch? It wasn't cheap and I don't want to accidentally fry it. It is ACDelco part D7057A and GM Part # 15687022. Additional info - it has 5 pins that would accept a female connector. Thanks!
jsetche is offline   Reply With Quote
Old 11-15-2008, 01:50 PM   #2
j cAT
j cAT Normal reputation
Re: 1998 Tahoe Fog Light Switch
this is not to be screwed with.....this switch operates a RELAY the relay then controls the lamps...
If you want fog lts get a swtich that can handle 15amps and mount where you can toggle the fog lamps on /off.....use a fused feed to your switch and the feed should come off the ignition feed...ignition on ,,then feed on...that way you won't forget to toggle off....kill battery..
I use these fog lamps during snow storms [white outs] very effective...
j cAT is offline   Reply With Quote
Old 11-15-2008, 05:26 PM   #3
jsetche
j cAT,
That being said, could I connect the factory fog light switch to a relay? My thinking is if I can figure out which of the 5 prongs on the switch are for the hot, ground and connection to the relay, I'd have it made.
Old 11-15-2008, 07:50 PM   #4
777stickman
777stickman's Avatar
777stickman Normal reputation
Send me a PM (private message) with your e-mail address and I will try (key word is try) to send you a fog light wiring schematic out of my '98 factory manual.
"R57 3CAR" 210 2dr post. 420HP 355 F/I 4sp 3:42 posi. (Dale Earnhardt tribute done by me.)
75 GMC Vandura 3/4 Ton
78 Chevy K5 Blazer
98 Chevy K2500 Suburban LT/7.4
05 Dodge Ram 3500/Cummins (Wifes horse hauler)
777stickman is offline   Reply With Quote
Old 11-16-2008, 08:39 PM   #5
jsetche
Thanks 777stickman. If I can get it to work, I'll post an update.
Bookmarks
Google
Web AF
