timing cover gasket
layitlo
11-13-2008, 10:31 PM
Has anyone changed out there timing cover gasket? If you have I was wandering how hard was it to do do it? I think mine is leaking oil but and I've never done one before. Thanks in advance.
RC1488
11-14-2008, 12:13 PM
Timing chain cover gasket? That is RTV, no gasket. Replacement is NOT easy.
Valve cover gasket (much more common for leaks): Easy replacement. You can use RTV, or depending on the year you can get pre-formed gaskets. Should take maybe 30 min at most to change. You can get the gasket at an autostore, online, or at the dealer
layitlo
11-14-2008, 12:41 PM
Oh ok I didn't know that. about the rtv. When I got the car there was a oil leak and the right hand valve cover bolt was leaking a little. I changed the oring on it and I didn't take the rest off. I really can't tell if the valve cover is leaking. The oil looks like it's coming from further down. I guess I might just take it somewhere and let someone look at it and see what one they say is leaking. Thanks for the headsup.
RC1488
11-14-2008, 12:54 PM
9/10 its the valve cover gasket. The timing chain gasket Rarely leaks. Actually Ive yet to see one leak.
layitlo
11-14-2008, 01:09 PM
Maybe I'll be lucky. I don't want to do the timing cover. Valve cover alot easier.:wink:
Scrapper
11-14-2008, 01:51 PM
is this in the truck you got on here? i had elcomino that i thot was leaking oil behind the harmotic balancer so pulled balencer off replaced that seal that never cured it so i took it all apart and timing chain wore a hole in cover and you couldn't tell it was timing chain it ran fine except oil leak. it had a 350 in it. but i would replace valve cover if leaking don't get cork get the rubber gasket if you do this.
layitlo
11-14-2008, 02:20 PM
Sorry I guess I should have said it was my saturn sc1. The blazer just needs valve seals to stop the smoking. I'm sure it leaks oil but not bad if it does. My saturn is my daily driver. The blazer is my minitruck project I'm working on and only driving from time to time.
